TryGetInteractionSourcePose Is failing (not unity, C++)
Please no unity answers.
The following code is failing for my app until I let the controller go to sleep and then resume while running. Not sure if this is a bug in the SDK or... ??
if(auto pose = state->TryGetPointerPose(currentCoordinateSystem)) { if(source->IsPointingSupported) { if(auto controllerPose = pose->TryGetInteractionSourcePose(source)) //FAILS { controllerRay = { convFloat3(controllerPose->Position), convFloat3(controllerPose->ForwardDirection) }; auto uwpQuat = controllerPose->Orientation; quat q(uwpQuat.x, uwpQuat.y, uwpQuat.z, uwpQuat.w); mat4 orientation4; q.toMatrix(orientation4.m); currentInputState.inputDevices[evState.deviceIndex].position = controllerRay.o; currentInputState.inputDevices[evState.deviceIndex].forwardVector = controllerRay.d; currentInputState.inputDevices[evState.deviceIndex].upVector = convFloat3(controllerPose->UpDirection); static mat4 poses[8]; currentInputState.inputDevices[evState.deviceIndex].pose = &poses[evState.deviceIndex]; poses[evState.deviceIndex] = orientation4; currentInputState.inputDevices[evState.deviceIndex].side = (evState.deviceIndex == 0) ? InputState::InputDevice::DS_RIGHT : InputState::InputDevice::DS_LEFT; evState.orientation = mat4GetMatrix3(orientation4); } } else { controllerRay = { convFloat3(pose->Head->Position), convFloat3(pose->Head->ForwardDirection) }; } }
I gave this another try last night. The API is definitely failing until I pause the app and let it stay paused for ... 5 seconds and then resume. This feels like a bug? Is there any info from MS or DirectX people as to a better workaround or should I just wait for another bugfix update?
Fixed on latest insider build
