Firewall on HoloLens
I am seeing strange behavior when trying to connect to a TCP port running on the HoloLens. It seems to only accept incoming connections on certain ports.
I wrote a UWP application that does the following:
listener = new StreamSocketListener();
listener.ConnectionReceived += OnConnection;
await listener.BindServiceNameAsync(PortTextBox.Text);
(Where the PortTextBox is an input field on the GUI.)
I have the proper capabilities set: Internet (client & server), Internet (client), Private Networks (client & server)
When the HoloLens listens on TCP port 9005, my laptop can successfully connect via Wifi.
However, if I try another port the HoloLens does not respond. (I've tried 4444, 9000, 9004.)
I ran Wireshark, and see the TCP SYN sent from my laptop, but no response from the HoloLens.
It seems like there is a Firewall running on the HoloLens that does a "drop" rather than a "reject" for unallowed ports.
Has anyone else experienced this issue?
I'm not personally familiar with this issue but I did some research. You're not the first person to report such a problem, though for the other person it seemed to resolve itself.
I also found a case where such an issue was reproduced by the team that owns the feature and they were going to look into it, but there was no response back.
If you're still dealing with the issue it would be good to document which ports are working and which are not, and I could attempt to get that information into that team.
Our Holographic world is here
I did some more investigating and have the following observations:
1) The HoloLens does not seem to respond to pings at all (over WiFi)
2) The HoloLens sometimes does not want to accept incoming TCP connections.
3) When the HoloLens does accept incoming TCP connections, it can at least listen to TCP port 9000-9100.
To remedy 2:
After that, I can seem to reliably connect from my machine to the HoloLens.
To determine 3:
Run nmap (or nc), to connect to those ports
Currently you need to enable the following capabilities in Package.appxmanifest:
Private networks (Client and Server)
Internet (Client and Server)
Internet (Client)
Now, the application should be able to connect to an any specified port.
