Shared Experience: Change server address dynamically
Hi, everyone.
I am currently working on a shared experience application. And I am using the "sharing" prefab provided in the HoloToolkit, and it works well following the course 240.
However, a big issue is that every time I launch the sharingservice.exe under different network, I need to rebuild the app and redeploy it onto all the HoloLens just to change the server address.
I heard about the solution of using static IP with the same router and the solution of putting my laptop's host name as server address. But I am facing the situation that I need to run the sharingservice.exe on different laptop AND under different networks (router) every time.
The only solution I can think of is to set up a cloud service (not applicable in my case), or give user the interface to change the server address dynamically in the application.
So I am wondering if anyone has tried out changing the server address dynamically in the app? Or is it even possible with the given scripts in the "sharing" prefab?
Thank you.
  • I am following https://github.com/Microsoft/MixedRealityToolkit/blob/master/Sharing/Src/Source/Docs/ExtendedDocs/GettingStarted.md to build the the sharing library, I think I have all the environment needed for running BuildAll.bat, but it failed with this error.
    Any hints on what the problem could be ?
    Build FAILED.
       "C:\Users\RUSSE\Downloads\MixedRealityToolkit-master\MixedRealityToolkit-master\Sharing\Src\Solutions\VisualStud
       io\HoloToolkit.Sharing.sln" (default target) (1) ->
       "C:\Users\RUSSE\Downloads\MixedRealityToolkit-master\MixedRealityToolkit-master\Sharing\Src\Projects\CommonUnive
       rsal\CommonUniversal.vcxproj" (default target) (4) ->
       (ClCompile target) ->
         C:\Users\RUSSE\Downloads\MixedRealityToolkit-master\MixedRealityToolkit-master\Sharing\Src\Source\Common\Priva
       te/TransformManager.h : warning C4819: The file contains a character that cannot be represented in the current c
       ode page (936). Save the file in Unicode format to prevent data loss [C:\Users\RUSSE\Downloads\MixedRealityToolk
       it-master\MixedRealityToolkit-master\Sharing\Src\Projects\CommonUniversal\CommonUniversal.vcxproj]
       te/TransformManager.h : error C2220: warning treated as error - no 'object' file generated [C:\Users\RUSSE\Downl
       oads\MixedRealityToolkit-master\MixedRealityToolkit-master\Sharing\Src\Projects\CommonUniversal\CommonUniversal.
       vcxproj]
    1 Warning(s)
    1 Error(s)
    Time Elapsed 00:00:03.66
    ********** Build Failed ***********
    Press any key to continue . . .
  • It says warning treated as error. I am curious if this is anything you even need to address. Perhaps follow these steps and see if it can just be ignored:
    https://stackoverflow.com/questions/2520853/warning-as-error-how-to-rid-these
  • Thank you so much for your help.
    But it has been a few days and I still could not figure out how to get started implementing auto discovery features using Unity. Do you by any chance know a sample project that demonstrate the auto server discovery?
  • Thank you so much! But I still get stuck in one problem:
    I enabled autoDiscoverServer and showDetailedLog in sharingStage. And according to sharingStage's debug message, it looks like in editor's play mode it can automatically find the server. But when I deploy it to HoloLens. HoloLens just kept looping in the stage "Looking for servers".
    PS: Even though in the editor's play mode the debug messages show that it found server and connected to the server, the server terminal never showed any message indicating that a client was connected.
  • Possible networking issue? Firewall, etc?
  • WanzeWanze
    edited September 2017
    Thank you Mark for your help and in time response. I tried updating unity and MRTK to the newest release and set network to private and discoverable, but still no help.
    I worked around and I decided to use static host name as a temporary solution.
  • I got the networking problem solved by enabling auto discover on the sharing prefab and totaly shutting down the firewall
    CEO UniVRsitas
  • However after establishing a connection between the hololenses and the sharing service the app doesn't work properly. I can't place the energy hub anymore. It just moves with my gaze and doesn't react to any air tap to place it.
    Anyone knows why this is so? I read that it takes 30-60 secs to 'export' the anchordata from the first hololens to the server but even after 2+mins waiting nothing happens..
    CEO UniVRsitas
