Unable to set tracking type to Stationary in Unity 2017.2.0b8
After upgrading from Unity 5.6.3p1-MRTP16 to Unity 2017.2.0b8 I've been unable to set the tracking space type to "Stationary" (as in for a seated experience). I call XRDevice.SetTrackingSpaceType with "Stationary", but Unity always behaves as if in RoomScale mode, and the camera position I set in the editor is taken as the floor level. Calling InputTracking.Recenter() afterwards has no effect.
Am I missing something? Here is a very simple test project here in case someone can help me with this: https://dl.dropboxusercontent.com/u/42976967/TestTrackingSpace.zip
To reproduce:
- Verify the "SetTrackingSpace" component attached to "Main Camera" is set to "Stationary"
- Run the game. The expected behavior is that the sphere should be at eye level. But instead the camera is elevated, taking its original position as the floor level.
- Pressing Space should recenter the tracking, but it also has no effect.
Thanks
Hi ,I have the same issue when update to Unity Beta10 and 11.Have you figure out how to fix that ?
Hi. No, I haven't. I reported this as a bug to Unity a while ago, but haven't received a reply from them either.
We are tracking this as well.
I have the same issue with SetTrackingSpaceType, are there any update about it ?
This has been resolved in the latest build of Unity. You can find the download link on this page.
https://forum.unity.com/threads/custom-build-2017-2-rc-mrtp-windows-mixed-reality-technical-preview.498253/
