Shared Experience: Change server address dynamically
Hi, everyone.
I am currently working on a shared experience application. And I am using the "sharing" prefab provided in the HoloToolkit, and it works well following the course 240.
However, a big issue is that every time I launch the sharingservice.exe under different network, I need to rebuild the app and redeploy it onto all the HoloLens just to change the server address.
I heard about the solution of using static IP with the same router and the solution of putting my laptop's host name as server address. But I am facing the situation that I need to run the sharingservice.exe on different laptop AND under different networks (router) every time.
The only solution I can think of is to set up a cloud service (not applicable in my case), or give user the interface to change the server address dynamically in the application.
So I am wondering if anyone has tried out changing the server address dynamically in the app? Or is it even possible with the given scripts in the "sharing" prefab?
Thank you.
Optionsmark_grossnickle ✭✭✭
They recently fixed autodiscovery:
https://github.com/Microsoft/MixedRealityToolkit/pull/106Grab the latest sharing server and client and they should find each other without having to manually change the IP
5 -
Here are the dll's you need. You should be able to replace them in your existing project.
External should be placed in your project folder at the same level as Assets and the .sln file.
Plugins should be placed in your Hooltoolkit's sharing folder.
I am following https://github.com/Microsoft/MixedRealityToolkit/blob/master/Sharing/Src/Source/Docs/ExtendedDocs/GettingStarted.md to build the the sharing library, I think I have all the environment needed for running BuildAll.bat, but it failed with this error.
Any hints on what the problem could be ?
Build FAILED.
Time Elapsed 00:00:03.66
********** Build Failed ***********
Press any key to continue . . .
It says warning treated as error. I am curious if this is anything you even need to address. Perhaps follow these steps and see if it can just be ignored:
https://stackoverflow.com/questions/2520853/warning-as-error-how-to-rid-these
Thank you so much for your help.
But it has been a few days and I still could not figure out how to get started implementing auto discovery features using Unity. Do you by any chance know a sample project that demonstrate the auto server discovery?
Thank you so much! But I still get stuck in one problem:
I enabled autoDiscoverServer and showDetailedLog in sharingStage. And according to sharingStage's debug message, it looks like in editor's play mode it can automatically find the server. But when I deploy it to HoloLens. HoloLens just kept looping in the stage "Looking for servers".
PS: Even though in the editor's play mode the debug messages show that it found server and connected to the server, the server terminal never showed any message indicating that a client was connected.
Possible networking issue? Firewall, etc?
Thank you Mark for your help and in time response. I tried updating unity and MRTK to the newest release and set network to private and discoverable, but still no help.
I worked around and I decided to use static host name as a temporary solution.
I got the networking problem solved by enabling auto discover on the sharing prefab and totaly shutting down the firewall
CEO UniVRsitas
However after establishing a connection between the hololenses and the sharing service the app doesn't work properly. I can't place the energy hub anymore. It just moves with my gaze and doesn't react to any air tap to place it.
Anyone knows why this is so? I read that it takes 30-60 secs to 'export' the anchordata from the first hololens to the server but even after 2+mins waiting nothing happens..
CEO UniVRsitas
