Launching a MixedReality immersive headset app opens and stays stuck , can someone solve my issue?
Can someone suggest me how to launch a Mixed Reality App for immersive devices(Acer , HP) from APPX App package which i also successfully installed but when launching just opens with the app scene and stays stuck showing Development build on bottom left , not an insider, but built the package from another PC which is a Insider!!. what would be the issue , is there any guidelines?
    I have attached the screenshots in the document below, and the thing is I can install the appx but when launching it just opens and stays stuck !!.
    My app was developed in Unity 2017.b 10 , creators update , insider preview and when launching in the same system it opens and works fine but when copying the app package in another system(not an insider preview) and installing is successful but when launched it opens and the scene stays stuck (shows Development build in bottom right of the screen )!. is there any steps or guidelines needed for not insider preview system, both systems are i7, 16GB RAM, GTX1060, and mixed reality portal with developer mode On!!.
    Hi Jesse, thanks for the replies and my Unity Build Settings -> SDK targeted to Latest Installed and highest version it shows was 10.0.16257.0 in the system where i built the app package and installing and running successfully , and the other system where i can install app from app package, but when launching scene go stuck and in that system I checked for Unity build setting SDK-> higher version was 10.0.16278.0!!.
    I have one more doubt , can't we install and launch the App package for Immersive devices in ( Not Insider preview)system ?
    Thanks a lot, Jesse!!.
    many Thanks for the help and clarifications!!. :):):):)
    You are quite welcome!
