How would I use an external library like Accord in my HoloLens Application?
Recently I've been trying to use certain external libraries in my HoloLens application.
Unfortunately, when I try to use the same, I get a number of errors describing either the .net version incompatibility or some Unity editor dependency error.
Is there a clean way to start using external libraries in the HoloLens dev environment?
https://github.com/accord-net/framework/wiki/Getting-started
@georgejakes - Any library you use has to be UWP compatible. I can't tell for sure, but I don't believe the library you linked to is.
@Jesse_McCulloch Thank you for the response, would you be able to recommend a list of such libraries for Math. I am looking for something that can perform Linear Algebra, unfortunately, my searches are coming empty
