C++/CX, how to safely use new APIs but also run on older windows 10
I need my app to still run on the HoloLens. How do I do this
Code
if(mStageReferenceFrame) mRenderer.reset(new Renderer(!HolographicDisplay::GetDefault()->IsOpaque, mStageReferenceFrame)); else mRenderer.reset(new Renderer(!HolographicDisplay::GetDefault()->IsOpaque, mStationaryReferenceFrame));
Api HolographicDisplay::GetDefault()->IsOpaque only available on fall creators. How do I check that is is available before calling on my old HoloLens which crashes with Platform::ClassNotRegisteredException
I need to solve this problem before next weekend.
Not exactly sure on this one but if you're trying to figure out HoloLens vs immersive headsets you can use the
Windows::Perception::Spatial::Surfaces::SpatialSurfaceObserver::IsSupported
https://docs.microsoft.com/en-us/uwp/api/Windows.Perception.Spatial.Surfaces.SpatialSurfaceObserver
Immersive headsets won't support this, but the HoloLens will.
Dwight Goins
http://dgoins.wordpress.com
No that's not what I'm asking. Out of time on this one as well, just going to require hololens to be on latest win10 before it can upgrade to this version package.
I found it. The solution is to get the api contract and test like so
