Voicechat in Holotoolkit Sharing
So, I was playing around in sharing component between my two hololens. It's been pretty good.
I came across the voice chat feature in the same section. It says, usage of just two scritps:
  • MircrophoneTransmitter.cs
  • MicrophoneReceiver.cs
Did anyone try using this? I couldn't find any help on their usage..
    chiddaanchiddaan
    Answer ✓
    I wasn't sure where to apply those scripts.
    I read on this thread, followed some steps, like attaching it to the camera instead and boom it worked.
    chiddaanchiddaan
    edited June 2017
    Well, I used those two scripts. Just added in my scene on the gameobject that has RemoteHeadManager.cs
    I am able to hear myself. And not other peoeple in the same session.
    Others as well are able to hear themselves.
    Thoughts?
    chiddaanchiddaan
    Answer ✓
    I also have problems by using two scripts(MircrophoneTransmitter.cs,MicrophoneReceiver.cs). My Problem is that I can hear my own voice,also others voice
    where to apply these scripts? Are you now clear? Thanks!
    @holofans You apply those scripts to your camera. and that's it.
    @WANGJUN You need to apply those scripts on your camera object in hierarchy. And that's it.
    I've applied those scripts to the camera, but I only hear my own voice. Is there something else I need to do? I'm using release bce6505 for 2017.2.1.0.
