"RenderTexture.GenerateMips failed"
I'm getting a steady stream of this error since updating to Insider Preview 16257. It's related to Unity's internal render process, not my code. Any ideas?
RenderTexture.GenerateMips failed: render texture does not have mip maps (set useMipMap to true).
UnityEditor.EditorGUIUtility:INTERNAL_CALL_RenderGameViewCamerasInternal(RenderTexture, Int32, Rect&, Vector2&, Boolean)
UnityEditor.EditorGUIUtility:RenderGameViewCamerasInternal(RenderTexture, Int32, Rect, Vector2, Boolean) (at C:\buildslave\unity\build\artifacts\generated\common\editor\EditorGUIUtilityBindings.gen.cs:642)
UnityEditor.GameView:OnGUI() (at C:\buildslave\unity\build\Editor\Mono\GameView\GameView.cs:747)
System.Reflection.MonoMethod:InternalInvoke(Object, Object[], Exception&)
System.Reflection.MonoMethod:Invoke(Object, BindingFlags, Binder, Object[], CultureInfo) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:222)
System.Reflection.MethodBase:Invoke(Object, Object[]) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MethodBase.cs:115)
UnityEditor.HostView:Invoke(String, Object) (at C:\buildslave\unity\build\Editor\Mono\HostView.cs:283)
UnityEditor.HostView:Invoke(String) (at C:\buildslave\unity\build\Editor\Mono\HostView.cs:276)
UnityEditor.HostView:InvokeOnGUI(Rect) (at C:\buildslave\unity\build\Editor\Mono\HostView.cs:243)
UnityEditor.DockArea:OldOnGUI() (at C:\buildslave\unity\build\Editor\Mono\GUI\DockArea.cs:383)
UnityEngine.Experimental.UIElements.IMGUIContainer:DoOnGUI(Event) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\IMGUIContainer.cs:127)
UnityEngine.Experimental.UIElements.IMGUIContainer:HandleEvent(EventBase) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\IMGUIContainer.cs:213)
UnityEngine.Experimental.UIElements.IMGUIContainer:DoRepaint(IStylePainter) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\IMGUIContainer.cs:50)
UnityEngine.Experimental.UIElements.Panel:PaintSubTree(Event, VisualElement, Matrix4x4, Rect) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\Panel.cs:447)
UnityEngine.Experimental.UIElements.Panel:PaintSubTree(Event, VisualElement, Matrix4x4, Rect) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\Panel.cs:457)
UnityEngine.Experimental.UIElements.Panel:Repaint(Event) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\Panel.cs:474)
UnityEngine.Experimental.UIElements.UIElementsUtility:DoDispatch(BaseVisualElementPanel) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\UIElementsUtility.cs:192)
UnityEngine.Experimental.UIElements.UIElementsUtility:ProcessEvent(Int32, IntPtr) (at C:\buildslave\unity\build\Runtime\UIElements\Managed\UIElementsUtility.cs:72)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr) (at C:\buildslave\unity\build\Runtime\IMGUI\Managed\GUIUtility.cs:175)
  • No idea but I've been getting the same thing.
  • Same but I'm not on the preview. Running 2017.1.0p5
  • I see of ton of "RenderTexture.GenerateMips failed" messages for 2017.1.0p5 in the HoloLens Emulator. I didn't see a workaround in the link provided by @Jesse_McCulloch. Is there one, or wait for the next patch? Thanks.
  • @tshadle - Should not need a work around. It's supposed to be a benign error. Are you seeing it actually effect your app?
  • @Jesse_McCulloch - I just tried it this morning, and though I got long series of messages the app did run in the emulator successfully. Thanks for following up.
  • It's sort of benign, but it spams the console so much it makes it hard to debug.
  • Just got this myself. Right, spamming the console making it hard to debug. Would be nice if the console window had a way to filter errors. Feature request!
  • I just got this error too and it drops performance dramatically.
  • I believe this has been fixed on 2017.2 - Is anyone still seeing it cause problems there? Or are we only talking about 2017.1 at this point?
  • Yes, the problem is fixed for me in 2012.2.0b11. Thank you for the suggestions. I have a weird choppy raycasting behaviour now though. Let's see if it's me or Unity...
  • stepan_stulovstepan_stulov ✭✭✭
    edited September 2017
    2017.2.0b11 also seems to not be visible behind the firewall despite being explicitly added as an exception.
    UPDATE: Firewall exceptions got confused about multiple Unity versions. Cleaned it up and it works.
  • Any news on how to deactivate/filter this message? It's quite annoying. I don't want to use Unity 2017.2 until it's out of beta.
  • @TortuousSplash - What is your definition for it being out of beta? The b releases are over and we are on to standard f releases now on 2017.2.0
  • For anyone who is looking for a way to filter or ignore console messages (and doesn't mind spending $30) there is an asset called Editor Console Pro by FlyingWorm that I tried out and it works well. Of course there are other features which I'm sure I will find useful for my 30 bucks...(I hope). Works with 2017.1.1 and the developer was quick to answer my question about how to ignore those messages. From that e-mail response:
    Go to Preferences -> Wrappers and Ignore, and there is an Ignore Logs section. Just press the + and put in:
    I hope Unity will consider taking a deal with Flying Worm to put this Asset into the base Unity IDE like they did with TextMeshPro.
  • The rendertexture error is fixed in 2017.1.2p1.
