HoloLens Bluetooth Ports
edited September 2017 in Questions And Answers
Hey guys!
I'm facing the problem, that I can't use the SerialPort Class in my WSA UWP HoloLens app, to read bluetooth input, because the Unity compiler complains the following, when I'm trying to build:
error CS0234: The type or namespace name 'Ports' does not exist in the namespace 'System.IO' (are you missing an assembly reference?)
Any help about fixing this is, or alternatives is greatly appreciated.
Thank you in advance,
jschnettker
    MondoMondo
    Hey,
    if the Unity compiler is complaining, try to use the #if NETFX_CORE flag.
    if NETFX_CORE
    • your code -
    endif
    MondoMondo
    Hey, try to use the #if NETFX_CORE flag.
    if NETFX_CORE -your code- #endif
    I tried to fix it, using the #if NETFX_CORE tag, but it keeps preventing me from building.
    That's the code I'm currently using:
    ``using UnityEngine;
    using System.IO;
    if NETFX_CORE
    using System.IO.Ports;
    endif
    using System;
    //using Windows.Devices.Bluetooth.Rfcomm;
    public class sizeManipulator: MonoBehaviour
    if NETFX_CORE
    public SerialPort serialPort = new SerialPort("COM3", 9600, Parity.None, 8);
    endif
    public static string strIn;
    //private char[] chars=new char[4];
    private string inputString;
    private float size;
    Vector3 startScale, scaleManipulation;
    void Start()
        //RfcommServiceId.AsString(RfcommServiceId.SerialPort);
        //GetPortNames();
    if NETFX_CORE
        string[] ports;
        ports = SerialPort.GetPortNames();
        foreach (String port in ports)
            Debug.Log(port);
        OpenConnection();
    endif
        startScale = new Vector3(transform.localScale.x, transform.localScale.y, transform.localScale.z);
        scaleManipulation = new Vector3(0f, 0f, 0f);
    void Update()
        inputString = string.Empty;
    if NETFX_CORE
        inputString=serialPort.ReadLine(/*chars,0,4*/);
    endif
        /*for (int i=0; i<4; i++)
            Debug.Log(chars[i]);
            inputString += chars[i];
            if (chars[i] == '\0')
                chars[i] ='0';
        Debug.Log(inputString);
        //inputString += ".0";
        scaleManipulation.x =(((float.Parse(inputString))/1023)-0.5f);
        transform.localScale=startScale+scaleManipulation;
    /*void GetPortNames()
        int p = (int)System.Environment.OSVersion.Platform;
        List<string> serial_ports = new List<string>();
        if(p == 4 || p == 128 || p == 6)
            string[] ttys = Directory.GetFiles("/dev/", "tty.*");
            foreach(string dev in ttys)
                if (dev.StartsWith("/dev/tty.*"))
                    serial_ports.Add(dev);
                Debug.Log(System.String.Format(dev));
    if NETFX_CORE
    public void OpenConnection()
        if(serialPort != null)
            if(serialPort.IsOpen)
                serialPort.Close();
                Debug.Log("Closing port, because it was already open!");
            else
                serialPort.Open();
                serialPort.ReadTimeout = 50;
                Debug.Log("Port Opened!");
         else
                print("Port is already open");
            else
                print("Port == null");
    void OnApplicationQuit()
        serialPort.Close();
        Debug.Log("Port closed!");
    endif
    Try to put the "using System.IO;" under the flag, too.
    (like "using System.IO.Ports;")
    @Mondo thanks for your reply!
    I tried it, but unfortunately it still prevents me from building.
    Ports is not a valid type in System.IO in UWP - https://msdn.microsoft.com/en-us/library/mt185496.aspx
    @Jesse_McCulloch Ok, thanks. Helps to know, what doesn't work.
    What alternatives do I have
    @jschnettker : You have to use RFCOMM
