Holograms 250 unstable
DineshPunni
Hey Devs,
i'm going through the Holograms 250 tutorial and after switching to Unity version 2017.2.0b11 it finally works (kinda).
The problem is that the 2nd HoloLens doen't always show the holograms from the first HoloLens. Also sometimes the position of the hologram is off by 1-2 meters.
Is there anything i can do to get a reliable sharing service running on 2 hololenses ?
(Edit): Found out that after (for whatever reason) one day the sharing works better than after deploy. So it takes the 2nd HoloLens approx. 1 day to get the spacial data of the first one.
Cheers,
Dinesh
CEO UniVRsitas
2
Hi, I`m having the same problem. Did anyone find something out ?
How does it work if we would like to use 3 hololenses?
Hi Have you looked at the thread Sharing with UNET client HoloLens - Rotation Displaced - Off
Similarities to your problems are described
