Is possible to change Point of focus on hololens ??
I want to recognized a Qr code from a distance of 40 cm but the Hololens camera doesn't have Autofocus. MY question is If is it possible to change point of focus on hololens camera?
Thank you for your help,
Lorenzo Orlandi
Same problem here, i try to recognize a PDF_417 but the camera have too poor quality for this type of bar codes and the hololens camera have a fixed focus.
Any advice?
Regards.-
@lollo,
Hi,you can try like this:
UnityEngine.VR.WSA.HolographicSettings.SetFocusPointForFrame(position, normal);
thank you for your answer but that function has another goal infact it is used to improve the visualization of the hologram. My problem regards the Point of focus of the Camera which acquires the image frame .
Thank you for your helping @shenwooash ,
