Hololens Holster
Ann
Hello. I'm working an AR project at USC and am looking to find/make a holster that will guarantee that the Hololens is always in the same starting location. Does anyone have any suggestions as to how a holster should be designed? Or where one can be found? I've found that a foam head can wear the Hololens but am not sure it'll be a reliable holster.
Whats your use case? Microsoft have some specifications for Spectator View that allows users to 3D print a bracket for the HoloLens.
The technology is somewhat old, but someone took a 12 inch by 12 inch cube block of polystyrene used for children's games and cut out the relevant area with an electric hot knife, 1/8 inch wire heated via a car battery.
The cutter is crude but the end result was good. If you have a Weller electric soldering iron. You can find or build a similar copper knife to cut out the area
For more professional approach see
see Styrofoam Carving Blocks
Then buy the Hot Wire Cutter and Accessories
Much cheaper than $300 for the HoloLens mount in metal , and probably much cheaper that the £199, that the online 3D print company will charge to print this.
You cannot fashion 3D plastic like polystyrene , you must reprint the lot!!(yep $199) a time
We're not using the holster for Spectator View. Instead, we're trying to get a placeholder that'll guarantee that the Hololens is always in the exact same starting place for each experience.
That sounds like a good idea. Thanks!
