How do you actually SaveAnchors and LoadAnchors
Hey guys,
how can you access SaveAnchors and LoadAnchors to a button, I went through the updated script and have no clue how to save anchor such as if I am going to see my holograms at the same spot after closing/reopening applications.
Also when is Microsoft ever going to show a video tutorial on how to use WorldAnchorStore
@ChrisSzkoda,
If you have an MRTK WorldAnchorManager in your scene, it should be pretty easy. Call WorldAnchorManager.Instance.AttachAnchor(gameObject) to store the object's location. If the object moves, you'll need to remove the anchor and reattach it when it is fixed again. Everything else should be automagical and the object's location will be remembered by the WorldAnchorManager between closing and reopening your app.
James
Does it save the 3D Objects as well as the WorldAnchor location? because we have attached the WorldAnchorManager to a gameobject but everytime we close and open, the gameobject moved from its previous location.
It uses the gameobject name to automatically reattach the anchor for you, which then places the gameobject. Do you have PersistentAnchors flag checked in your WorldAnchorManager?
