Xbox controller and Hololens?
So I know you can connect an Xbox controller to the HoloLens but I have yet to find any good documentation on this. Is it HoloLens specific or do I just need to look at a Unity specific guide for Xbox controllers?
AR Developer
dbarrett ✭✭✭
@greensauce yes, it is now a part of the MRTK. Specifically, you should take a look at IXboxControlllerInput. You should inherit from that script. Then inside of the
OnXboxInputUpdate
is where you do all your checks witheventData
. If you want to know what all is support by eventData, check out theXboxControllerEventData
script. All of these can be found inside of the Input Folder of the MRTK.AR Developer
@dbarrett,
You will need an Xbox One controller that supports Bluetooth. These came out at the same time as the Xbox One S system and the description will indicate Bluetooth support. (I'm including a link to one of the Bluetooth supported models for reference).
You can then pair it to your HoloLens using Settings > Devices.
David
@dbarrett,
What David said plus, to make things easier, the 2017.1.2 HTK has this new toolbar configurator in the build and deploy module:
My question was more along the lines of how do I register Xbox controller input on the HoloLens. Sorry for the confusion. But still good info here
AR Developer
This is actually only half the truth
Any controller will do... If it is supported by this project https://github.com/x360ce/x360ce
I use for example a Logitech Wireless F710. And it works perfectly.
Edit: Nevermind.... I figured out ... It is about the hololens
... What I wrote is gibberish
@dbarrett Did you ever find documentation about how to register input? When I pair up my controller (Xbox w/BT) to the HoloLens I can get the D-pad to cycle in the menus but that seems to be it. I'm pretty surprised there isn't a tutorial set in the Academy series about how to do this.
OnXboxInputUpdate
@dbarrett Thanks for the information. Unfortunately I am not a software engineer so I can't make much use of it currently. I have also found that whenever I add the MRTK package to a Unity project I get dozens of fatal build errors.
@greensauce make sure you have everything that you need to build HoloLens apps installed on your computer.
AR Developer
