Holograms 101 Spatial Mapping
I am running into an issue in the spatial mapping section of the tutorial. Everything works perfectly fine until I add the spatial mapping asset to the scene. When I run the app, the origami collection appears for a second with no spatial mapping meshes, and then the origami collection disappears. All that is left is the spatial mapping mesh of the environment and the gaze cursor. Does anyone else have the same problem and know of a solution?
I am using Unity 2017.1.1f1.
    wanglabwanglab
    Answer ✓
    Resolved.
    Change the Render State setting for the Spatial Mapping Renderer to Visualization.
    james_ashleyjames_ashley ✭✭✭✭
    @wanglab,
    The origami collection is likely falling from it's initial location and falling through the floor before the mesh is completed (that would be my guess). To test this, turn gravity off on your collection and see what happens.
    James
    @james_ashley,
    Thanks for the response. The origami collection does not have a rigid body component and thus has no option to turn gravity on or off. Also it did not have this behavior before I added the spatial mapping.
    wanglabwanglab
    Answer ✓
    Resolved.
    Good job.
