Enable Multisample AntiAliasing
Damien
Hi everyone,
I'm developing a mixed reality app with HoloLens. I'm not using UNITY. My application is based on HoloLens UWP app available on GitHub.
I would like enable the Multisample antiliasing feature but I don't know how to enable it.
I set at TRUE the MultiSampleEnable in my rasterizer - no success.
The HololensUWP sample apps do not access the swap chain directly. So it seems difficult to set correctly the SampleDesc.Count (like in this example : https://gamedev.stackexchange.com/questions/129437/cannot-enable-4x-msaa-anti-aliasing-in-directx-11)
Any idea ?
Thanks !
While I personally haven't tried to do this yet. This may be possible. Take a look at this link It appears to be the approach you have to take.
It isn't so obvious due to the swap chain handled by the OS instead. This idea is to create a multisampled render target and render to the back buffers provided by the holographic camera parameters and replace it with the multisampled buffers.
Dwight Goins
http://dgoins.wordpress.com
