How do you get position of the controller of with unity?
I have been using the interaction manager to connect the controllers (which are tricky as it appears I have to push windows button, go to mixed reality portal and then back to unity for it to connect, any clues how to make it connect are appreciated) and it doesn't seem to matter what I have the SourcePos never returns a position.
Can anyone get this work and if so what is the trick?
Script below
using System.Collections;
using UnityEngine;
using UnityEngine.XR;
using UnityEngine.XR.WSA.Input;
public class ControllerInput : MonoBehaviour {
// Use this for initialization void Start () { InteractionManager.InteractionSourceDetected += InteractionManager_SourceDetected; InteractionManager.InteractionSourceUpdated += InteractionManager_SourceUpdated; InteractionManager.InteractionSourceLost += InteractionManager_SourceLost; InteractionManager.InteractionSourcePressed += InteractionManager_SourcePressed; InteractionManager.InteractionSourceReleased += InteractionManager_SourceReleased; } void OnDestroy() { InteractionManager.InteractionSourceDetected -= InteractionManager_SourceDetected; InteractionManager.InteractionSourceUpdated -= InteractionManager_SourceUpdated; InteractionManager.InteractionSourceLost -= InteractionManager_SourceLost; InteractionManager.InteractionSourcePressed -= InteractionManager_SourcePressed; InteractionManager.InteractionSourceReleased -= InteractionManager_SourceReleased; } // Update is called once per frame void Update () { //Vector3 leftPosition = InputTracking.GetLocalPosition(XRNode.LeftHand); //Debug.Log("LP" + leftPosition); var interactionSourceStates = InteractionManager.GetCurrentReading(); Debug.Log("Num Interaction Source States: " + interactionSourceStates.Length); /* if (interactionSourceStates.selectPressed) { Debug.Log("Press" + Time.time); } */ if (Input.GetButton("Fire1")) { Debug.Log("Fire1"); } } void InteractionManager_SourcePressed(InteractionSourcePressedEventArgs args) { Debug.Log("Source pressed"); } void InteractionManager_SourceDetected(InteractionSourceDetectedEventArgs args) { Debug.Log("Source detected"); } void InteractionManager_SourceUpdated(InteractionSourceUpdatedEventArgs args) { Vector3 p; //float a; args.state.sourcePose.TryGetPosition(out p); //a = args.state.sourcePose.positionAccuracy; //Debug.Log("Source updated " + p); } void InteractionManager_SourceLost(InteractionSourceLostEventArgs args) { Debug.Log("Source lost"); } void InteractionManager_SourceReleased(InteractionSourceReleasedEventArgs args) { Debug.Log("Source released"); }
I'm also having this issue just in the MotionControllerTest scene in the MRTK
I am using the standard unity build
I find that I need to close the mixed reality portal every time before launching from unity for the controllers to work.
