Sensor Size of Locatable Camera
Hey,
Do any of you have specs of the webcam?
I want to estimate the distance between the hololens and objects i detected in the bitmap from the camera. To do this i need the focal length of the camera, its sensor size in mm, the image size in px, the object size inside the image in px and the object size in mm. The only parameter i'm missing is the sensor size.
I couldn't find any info about the camera's specs online, do you know more?
Thanks a lot!
