Spectator View Compositor not working
Hey Folks,
I've got almost everything working to get the Spectator View working in my application. Followed this tutorial: https://developer.microsoft.com/en-us/windows/holographic/spectator_view
Calibration is good, got the camera feed from that, the problem I'm having is the compositor is not working at all. No button presses do anything except "Toggle Full Screen" which gives me a blank full screen.
This is all I see when running the compositor, no video feed from the camera, no feed from the hololens'. Hololens' are attached to the sharing service and I can see the avatars I've made in each of them.
Here are a few errors I'm having:
When opening up the compositor, I get:
Failed to call static function Reset because an object was provided
UnityEditor.EditorWindow:GetWindow(Type, Boolean, String, Boolean)
CompositorWindow:ShowWindow() (at Assets/Addons/HolographicCameraRig/Editor/CompositorWindow.cs:108)
After using CopyDLL.cmd, and opening the project, I get the following errors as well:
Removing Assets/Addons/HolographicCameraRig/Plugins/x64/EDSDK.dll because the asset does not exist
Removing Assets/Addons/HolographicCameraRig/Plugins/x86/EDSDK.dll because the asset does not exist
Removing Assets/Addons/HolographicCameraRig/Plugins/x64/EdsImage.dll because the asset does not exist
Removing Assets/Addons/HolographicCameraRig/Plugins/x86/EdsImage.dll because the asset does not exist
This happens in both my project, as well as the sample project.
Thank you!
    RLekeyRLekey
    Answer ✓
    Hey So I figured it out and it was pretty dumb. The editor needed to be in play mode to connect to the sharing service.
    Hopefully I help someone else being a dummy like me.
    RLekeyRLekey
    Answer ✓
    Thanks for the tip. I thought it would be running at editor mode. <3
    But I got no camera feed at the compositor window, did you have any clues?
    Everything goes fine when taking pictures and the captured photo mixed well with the holograms. Still the compositor cannot receive the stream. I'm sure there's no other software using the camera. I am so upset now...
    Are my hardware configurations not qualified? I used E31231v3 CPU and Blackmagic Intensity Pro 4K with a AMD FirePro W2100 GPU to handle the job.
    Fixed. https://bitbucket.org/Unity-Technologies/unitytesttools/issues/12/error-when-you-open-unity-and-the-unit
    Here's the unity issue tracker.
    First import the dlls in prior editons of unity for example 5.5.0f3. Ignore the bugs and reopen the project with newer editons for example 5.6.2f1. Everything works perfect now.
