Emulator and localhost
I am trying to run one of our UWA solutions in the HoloLens emulator. Our app points to a service that is running in another instance of Visual Studio on my machine which is exposed to the UWA app over a localhost and port address.
The HoloLens emulator does not seem to be able to see localhost as it is configured out of the box. To confirm that it wasn't some other issue in our UWA app, I did a simple test and opened the Edge browser in the emulator and typed in the localhost:port address of the service (which also works from a browser). The Edge browser in the emulator threw a "Hmm, we can't reach this page." error, so I suspect that it has to do with the Hyper V VM configuration.
Is it possible to configure the Hyper V and the HoloLens emulator instance so that it can see localhost when debugging these kinds of solutions? If so, are there any simple instructions on how to make the necessary configuration changes?
Thanks.
ahillier mod
Here's a workaround that we found for running the Academy 240 course with the emulator on localhost:
1) Use the ipv4 for the emulator switch as the server address instead of your local ipv4 that you would have otherwise used.
2) When you launch the sharing service, make sure you check all the firewall boxes.
This means that you probably won’t be able to use another emulator on a second PC with this sharing service (To do this you would do the workaround we had earlier with 3 pc’s: 1 running the sharing service, the other 2 running their own emulators).
8
Maybe is a stupid comment, But if you ipconfig in cmd, you are able to see different IPs when running Hyper-V.One is for the emulator I think...
Hi @HoloSheep ,
I am facing the same problem now. I try to connect to localhost and it seems with Hololens Emulator it is not possible. I have try with my universal app with other emulator for other device and it works perfectly. Someone point out in other post something similar. Do you have a solution?
Hi @DiegoV,
I did find a blog post that was talking about something similar with HyperV, however I was not successful in using the info in that post to get a 2D UWA app on the HoloLens emulator to connect through localhost to another service app on my pc.
Ultimately, we had to leverage a cloud relaying feature in our application to work around it, but it would still be helpful to find a way to configure the HoloLens emulator in the VM to work with localhost on the underlying machine for better development and debugging productivity.
Hi @HoloSheep
Yes, I have added a new post with this question here.
I am doing my tests with another Emulator Windows 10 an it works ok. But indeed when I use gestures or other things in HoloLens it will be a mess to communicate. With real device I think we will not have problems due to is a normal computer ( I guess) maybe somebody from Microsoft can confirm...
Thank you for reporting this issue. We are investigating this.
Dear @ChimeraScorn ,
Any update?
Its all about TCP/IP network routing. Localhost on the HoloLens Emulator is server one network gateway created by Hyper-v namely 172.x.80.1 and your Windows 10 is on another Localhost on gateway , possibly 192exter.pri168.x.1, the default subnet mask is set to split the networks namely 255.255.255.0, therefore you cannot talk to a port 80 webserver on Windows 10, from Windows Holographic emulator. You can talk to the router and Internet without any problems at its subnet mask allows any connection. The Hyper-v network address is fixed, if you manually set new addresses the Hyper-v code will change them back!!!!.
So in summary its a Hyper-v problems NOT an emulator problem. Hyper-v Manager can only change from internal to private. If you set external you will Hang the Emulator in OS starting.
Hi @Jimbohalo10 ,
So why I can do the same with another Windows Emulator? In my case I am able to connect with TCP with any Windows Emulator(512MB, 1 GB RAM) with the exception of Hololens emulator.
Maybe its the way the Hyper-v is created, but having reconfiguring my network to make this work on for a while I connected two pc with emulators to talk to each other I expect there is some deeper reason in Hyper-v blocking this activity. On a single pc local loopback 127.0.0.1 has been blocked in the emulator and ping responding does not work which is outside scope of this thread
@Jimbohalo10 Yes that's it. I have a local network with direction 192.168.0.X. I have my a host in my computer. I have the exception "No IPEndpoints were found for host 192.168.0.16" that its my computers IP. For enable internet in my hololens I used this post With other emulator works perfect with hololens no. As an additional clue I have run in cmd "netstat -a " command. As soon as I start Hololens a lot of services appear there. If you find any clue please let me know.
Have you tried using Fiddler2? Not that I've tried this with Hololens yet, but I've got this to work on Windows 10 Mobile, so it could be worth a shot. I use it to monitor and decrypt SSL connections within the emulator and hardware. Since Fiddler2 is running on the host, you should be able to access a program/IIS running on the host using their reverse-proxy feature.
http://docs.telerik.com/fiddler/configure-fiddler/tasks/monitorwindowsphone7
http://docs.telerik.com/fiddler/Configure-Fiddler/Tasks/UseFiddlerAsReverseProxy
Finally I was able to do it with 2 computers, but the latency with emulator is horrible. With the app running in one of the computers goes better. Even with a mobile emulation. Maybe the network is not a "real emulation behavior"
Hi @HoloSheep ,
I have found this interesting note here. As it seems that Hololens communication is based on sockets. I think that this is the problem that we are experiencing.
Note: As part of network isolation, the system forbids establishing socket connections (Sockets or WinSock) between two UWP apps running on the same machine via either the local loopback address (127.0.0.0) or explicitly specifying the local IP address. This means that you cannot use sockets to communicate between two UWP apps. UWP supplies other mechanisms for communicating between apps. See App-to-app communications for details.
This appears to be the new way UWP apps will have to communicate over TCP ControlChannelTrigger Class
Looking like going back to Networking-Basics
More overview in the way UWP is taking dev programs Networking
There is a page about this 127.0.0.1 problem in debug for stream sockets at https://msdn.microsoft.com/en-us/library/windows/apps/hh780593
which describes how to enable loopback using "CheckNetIsolation.exe LoopbackExempt GUID number"
This is high advanced level coding and network control so may not be for everyone
Hi HoloSheep,
I have a server based on WinSock running on a computer. The client is also based on the Winsock but running on the emulator. I cannot connect to the server from the emulator.
How to deal with this issue?
Many thanks.
