Work with 3d model as spatial mapping
Hi! I am developing with holotoolkit. I need to know if it can be used on the proyect I am thinking about.
In a truck assembly line, I find myself in a static environment, but the trucks are moving slowly forward. For each truck, I need to look at the back and place a 3D plane(prefab) that fits the trailer in the same place on all trucks.
the plane must fit into the trailer floor.
Is any way for make this with hololens??
Thanks a los. Any information is helpful.
    Thank you for your answer, but I can't use any markers. I cant add anything to the truck trailer.
    To recognize the back of truck I should use Vuforia tracking 3D that is not workig yet.
    Other way to make this?
    Thanks for the answers. I assumed it was going to be difficult not to say impossible at the moment. I'll have to wait for Vuforia's 3D tracking.
    Thank you.
