Why is my Unity app creating a 2D billboard and not allowing me to enter the 3d app?
I have been creating a Unity app for the Hololens. Earlier this week when I deploy the app the hololens would open straight up to the app and display the holograms. Now after changing no settings and only opening up the device portal It creates a billboard with my app inside. This board allows me to place it on the wall but never enter the 3d space of unity. How do I fix this so that I can interact with my holograms inside of unity? I have attached a picture of what my app looks like now with the billboarding. Clicking on the app does nothing.
    I believe this is under your build settings in Unity. Change your Build type from XAML to D3D
    AR Developer
    Cspicer25Cspicer25
    edited October 2017
    Here is a picture of the build settings I used. I think I already have D3D selected. Is there anything else that would cause this? I was able to build and interact this scene earlier in the week.
    james_ashleyjames_ashley ✭✭✭✭
    You need to reset the Spatial Perception capability to true. Not sure why this would happen if you didn't make any changes though.
    If none of the above are working for you, in my case, I had to make sure all the proper Unity modules were re-installed. Also take note when you install from Unity Hub, sometimes this doesn't get all the modules. For example: .Net, IL2CPP, etc. Because of all the different versions of Unity, and building for other devices you can easily get out of sync.
    Dwight Goins
    http://dgoins.wordpress.com
    I met same situation. Have you solved this?
    If you have any advice, thanks a lot.
