Hololens in Enterprise Network
Hello everyone
We will deploy a Hololens experience in an enterprise setting. The device will be connected to a WPA2-Enterprise Network (Username & Password) and will be behind a restrictive Firewall and UDP Traffic is mostly blocked. We can connect to the network without a problem (on the Hololens) and internet access over 80/443 seems to work fine.
In the Hololens documentation it states that it needs internet access for positioning of holograms but I could not find any information regarding what kind of ports and protocols are involved and are needed for the Hololens to work correctly. What requirements are there? Do we need anything special on the Network side to make sure it all works as it should?
We seem to have an issue where the Hololens can't determine in which space it currently is. We never had this issue before on other networks but are not entirely sure if it is related to the network. It will show an error to select the space on the start menu and also ask to select one. If the network configuration is the cause of this it would be great to find out what the issue is.
    james_ashleyjames_ashley ✭✭✭✭
    @Chrigi,
    The HoloLens uses ip geolocation to determine where you are and then associates this with spaces it maps (HoloLens doesn't have a GPS chip). The results you are seeing happens when the location can't be determined. Best guess is your firewall configuration is blocking ip geolocation.
    James
    @Chrigi
    Is the HoloLens giving you the option to select a space, or is it only giving you the option to use in limited mode?
    Actually it was quite strange: It did offer me to select the correct space but it did not save this information. The second time it had the same issue. I now deleted all spaces and rebooted the Hololens. Now it seems happy. It could re-scan the room and restarting the device still locates it in the correct space but it takes way longer to locate than at another place.
