Hololens App: Is it Possible to Launch a Unity app from another Unity App
sreehari
in Discussion
Hi, Is it possible to launch another Unity application from within a Unity application? If I Click a button in one application it would launch another application that is installed in Hololens. I would be very grateful if I could get example code on these specific requirement.
Thank You,
Hi Sreehari,
On Hololens, it is not possible to launch another Unity application from within a Unity application at this time.
Thanks for the suggestion and I will forward it on to the product team.
Yang
This is actually possible as long as you know the URI associated with the Unity app you can use launch URI to launch another Unity App.
AR Developer
Here's the regular UWP way to do it: https://docs.microsoft.com/en-us/uwp/api/windows.system.launcher
That said, some apps like Skype don't seem to work -- so the launcher may behave differently on HoloLens.
