Replacing Hololens Camera Position
Is it at all possible for me to simulate the Hololens Camera moving in a way I specify? For example, could I decrement the y value in a manner so as to make it look like the user is going down? I've tried to make this happen, but it doesn't seem to work.
Optionsstepan_stulov ✭✭✭
Hey, @TetraTalon
Assuming HoloLens...
I'm not sure this can be properly imagined, let alone implemented? Camera transform (position + rotation) are controlled by the hardware/OS and the whole idea is so that it's synced with your head.
However, I could imagine the following setup. Imagine you have a bunch of invisible world-anchored holograms and a not-so-much-a-camera dummy object moving along some predefined spline. Now you can read those invisible holograms' transforms relative to that dummy flying camera and show real holograms with the same relation to your own camera that's controlled by your head movement. Anchoring can be taken out of this setup too depending on the goal you're trying to achieve.
Essentially that won't be controlling the camera though, but creating an illusion of such. Since when wearing a HoloLens you still see the world, you won't (if I may speculate) feel like you're moving somewhere, it will be the scenario passing by you. Then again, the whole AR/VR/MR is one big illusion, so hey
Hope this helps.
6
Hey, @TetraTalon
Hope this helps.
@stepan_stulov How would you achieve the relative transform effect? I actually have a gps that I'm reading in data from so I can actively update my position, but I'm guessing I'm going to have to lerp the environment around me as I move. It's all a little hard for me to work out mathematically.
I've had exactly the same issue with a GPS unit like you. I achieved by parenting the "world" to a virtual camera (empty game object), then every position update I swap the 2 around (make the camera the parent and the world the child) and then move and rotate the virtual camera to the hololens camera. Bonus is that the Hololens handles position updates nicely in between GPS position updates. Just make sure that the position enters the Hololens as soon as possible with no delay.
Still too bad that the environmental-spatial-understanding-mapping-stuff can't be turned off though.
@TetraTalon How do you connect to the GPS by the way? Bluetooth? I guess you also need some way to have a compass?
Hye, @TetraTalon
Essentially you will need to convert a position+rotation between two coordinate systems. You will use these two methods I'd imagine:
Transform.TransformPoint()
Transform.InverseTransformPoint()
Something along those lines:
realObject.transform.localPosition = realCamera.transform.InverseTransformPoint(dummyCamera.TransformPoint(dummyObject.transport.localPosition));
You'd need to take care of the rotations too. This code is just some quick thought and is not expected to be used directly. Additionally apply smoothing/lerp if necessary to prevent choppiness. As you see you don't need to deal with real math, vectors and quaternions. Unity's got a ton of convenient methods for transforming things there and back.
Hope this helps.
@arjan_wiegel How frequently do you update? I'm using a UDP broadcast to get the gps position. Also, I've been able to disable the spatial mapping (since I'm trying to use this outside) by covering the sensors, and changing how the program reacts when tracking becomes unavailable. It's not a great solution, but it seems to work for now.
@stepan_stulov Thanks for the functions! Could you explain your real and dummy object concept a little further please?
Hi, i probably have the same situation here. I have external position tracking device binding on top of the hololens, i have tried many ways to update hololens transforming with the external tracking data, but some time the tracking can be very jittery especially if the headset is moving.
Could you please give me more info about your approach? Such as what is the ”world” mean? and how to “move and rotate the virtual camera to the hololens camera”? Just assign the hololens camera’s position and rotation to the virtual camera?
@summertao a bit late, but hope it might be of some help:
My tracking is also very jittery. The cause of this is the delay that the GPS/compass data is received.
with the world I mean the root of the scene. Parenting something to "world"is just transform.parent=null.
“move and rotate the virtual camera to the hololens camera” could be coded as:
virtualcamera.transform.position=hololensCamera.transform.position;
virtualcamera.transform.rotation=hololensCamera.transform.rotation;
Hope this helps...
