Which version holotoolkit pacakage is the best version for the unity 2017.2.0f3? These have errors!
The Unity version is 2017.2.0f3, and I create the new unity project and import the holotoolkit and holotoolkit-example unity pacakages, and build the colorPicker scene. But the console show the errors like below.
And I think I have finished the holotoolkit configuration well, it like this.
So, has anyone meet the same problems? Or has anyone build holotoolkit samples with the Unity 2017.2.0f3?
    Sorry, I forgot to tell you the holotoolkit pacakage version!
    I have test the version HoloToolkit-Unity-Examples-v1.2017.2.0, HoloToolkit-Unity-Examples-v1.Dev.2017.2.1, and even I download the current MixedRealityToolkit-Unity-master from the github website, and then build the colorPicker scene, the same error happened again!
    Hope someone can tell me why and how to solve them?
    I had the same issues. seems like there are 2 ways streaming into 1 right now so information is in flux. use 2017.1.2fx + master branch toolkit for hololens. use 2017.2.0p1-MRTP4 + master branch for MR apps. even when i had that set up i got errors after enabling XBOX controller support in the MR toolkit menus. SO i reinstalled everything using the unity download assistants for thier respective unity versions. but then the error came back again. might be some where thing where file handle stays held then when you try to build it trips. good luck my stuff is workign now.
    also everytime you use the MR tools to change settigns make sure you check the other settings didnt get wiped out.
