Shader is not supported on this GPU (none of subshaders/fallbacks are suitable)
Getting this error with the shader from Holo Toolkit. Any suggestions? Shows pink colored texture.
Are you targeting UWP in Unity?
What version of unity are you using, which shader is it, and what version of the Toolkit are you using?
Try updating the toolkit to the latest and use Unity 2017.2.
Take a look at Custom Unity Shaders on HoloLens
See HoloLens Shader Pack
