VS2017 failed to deploy to my hp mr
I created the holographic application using default vs2017 holographic template.But it failed to deploy to the device, the error message:"Deployment failed because no device was detected. Make sure a device is connected and powered on. [0x80131500]". But my mr device works correctly! I have also enabled develop mode. so what's wrong
Optionsyyao ✭
Yes, I have tried the local machine. VS 2017 default holographic template (both c# and c++) crashes. I have reported this question. And MS has marked it as VS bug.
You did not have the mixed reality portal running hence the error. You must be able to see the cliff room floor before deploying. In the headset get the desktop app running then click deploy to vs2017, from inside headset with mouse. Use local machine, device is for HoloLens
see https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_100 tutorials to mixed reality headset
