Spatial Mapping of simple 3D objects
Hi All,
We are creating a manual for a simple machine.
Can we create a 3d model of the machine using spatial mapping and not the whole room?
The holograms which are simple UI elements need to hang on its vertical surface. Can we stick a hologram on a surface or will gravity pull it down?
Harish
Hello, Harrish.
If I may, you need to untangle the concepts you're asking about.
Hope this helps.
Thank you, Stepan. I had all the concepts confused.
Apologies, @harish, not Harrish. One R.
