Azure Server for Sharing Service
Did anyone tried using Azure server for sharing service. We are having a road block as it doesn't provide the public IP
Yes, you can definitely get this to work in Azure as I've done it myself in the past.
I don't have a step-by-step guide for you but others on the forum have also made it work and it looks like this post https://forums.hololens.com/discussion/959/holotoolkit-unity-sharing-in-azure might be the guide that you're looking for.
Hope it works for you.
