Failed to locate env variables VS140COMNTOOLS or VS120COMNTOOLS
Volkert
Hello, i'm using Unity2017.2.0f3 and VS2017
When i make a build for the hololens i'm getting the following error:
I used all the settings from:
https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_101
Has anyone already had this one? and how was it solved?
V
I ran into the same issue after wiping my computer and re-installing Unity 2017 and VS2017.
Adding the following variable to your environmental variables and restarting Unity did the trick as found here:
https://forum.unity.com/threads/exception-failed-to-locate-env-variables-vs140comntools-or-vs120comntools.474195/
variable to add:
VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\Tools
