Get Position of Mixed Reality
aram
Hello
I try to build a .dll which can get position of several VR-Devices.
Oculus and OpenVR is already implemented using Oculus SDK and OpenVR SDK.
For the Windows Mixed Reality HMD, I need access to the Windows 10 UWP API.
1) How can I access / call functions from the Windows 10 UWP API from a normal C++ Visual Studio Project without generating a UWP app ?
2) Is it at all possible altough the DualApiPartition Attribute is not set for the desired function ?
I already tried the C++/WinRT language projection by Kenny Kerr which seems also not to work.
Any advise or help is much appreciated!
Hi, has this question been solved?? I have the same question ,too.
@Tingwei
It works now for me.
The best solution is, in my opinion, the C++/WinRT language projection by Kenny Kerr. You can check it out here: https://moderncpp.com/
You can follow the instructions on GitHub.
Make sure you are using Windows Version 1709.
The classes you need are basically these: https://docs.microsoft.com/en-us/uwp/api/windows.perception.spatial
Good Luck!
@aram Thanks, I will try !!
