is it possible to change the Astronaut in to different 3D model ?
I am quiet sure many people asked the same question. I am beginner in Hololens and following Hololens academy
Astronaut is the 3D model in the academy lessons can i change this model and include my own model ? because there is a expansion objects and other scripts are also included how to handle them ?
can someone help me out with that ?
Optionsmark_grossnickle ✭✭✭
Absolutely you can change the model. I don't have the project in front of me but in general you can swap out the model itself within existing prefabs or drop in new prefabs.
In either case, if you need scripts applied to the model then you can copy them from the old and paste them on the new before removing the old.
But do take the time to figure out what exactly you are copying and pasting. It may be worthwhile to go through some general Unity tutorials. They have a ton of content on their website.
Thanks it helped
