Cannot access HoloLens' Camera Roll from Unity App
Greetings,
I am trying to access and display JPGs from the HoloLens' Camera Roll in my Unity app.
I am using this code:
imageRootDir = Windows.Storage.KnownFolders.CameraRoll.Path.ToString();
string[] filePaths = System.IO.Directory.GetFiles(imageRootDir);
imageRootDir resolves to this directory:
C:\Data\Users\sally\Pictures\Camera Roll
filePaths returns an array of length zero.
System.IO.Directory.Exists(imageRootDir) returns true.
I can see there are several images in the Camera Roll via the HoloLens file explorer. Any hint what I might be doing wrong in the Unity app?
Thank you for your support.
    dbarrettdbarrett ✭✭✭
    edited December 2017
    Have you enabled the Pictures Library permission under the Player Settings?
    I have made an app the can save the photos but, I haven't tried to display them from memory as I display them as soon as I take the picture. The file path you are using is correct.
    Make sure when you are saving/calling from memory it is best to use string filePath = Path.Combine(imageRootPath, filename);
    AR Developer
    Hey dbarrett, thank you for the reply: I do have Pictures Library enabled.
    The following are currently enabled:
    InternetClient
    InternetClientServer
    PicturesLibrary
    WebCam
    Microphone
    SpatialPerception
    Thank you for the ideas.
    sallysally
    Thank you dbarrett, that solved my problem! I will include some notes below which may help the next user:
    • I had to update Unity's Scripting Runtime Version to "Experimental (.NET 4.6 Equivalent)" in order to get the async/await functionality working.
    • I set up the following using statements:
      using System;
      #if !UNITY_EDITOR && UNITY_WSA
      using Windows.Storage;
      using Windows.Storage.Search;
      #endif
    • I created a function like this:
      public async void DoTest()
      StorageFolder CameraFolder = Windows.Storage.KnownFolders.CameraRoll;
      IReadOnlyList filesInFolder = await CameraFolder.GetFilesAsync();
      #endif
    filesInFolder then correctly populated to a List of four items.
    Thank you for your support!
