Ignore Scaling UWP App In Hololens.
Windows 10 automatically applies a scale factor to UWP apps, to give a similar effective pixel size across multiple devices (https://blogs.technet.microsoft.com/supportingwindows/2015/12/08/display-scaling-in-windows-10/).
When running my UWP app on the Hololens it applies a 150% scale factor.
I want to ignore this, as I want my UI to look the same across any screen of the same resolution (1280x720). Is this possible?
Some people suggest using TrySetDisableLayoutScaling (https://docs.microsoft.com/en-us/uwp/api/windows.ui.viewmanagement.applicationviewscaling) but this only seems to work for Xbox.
I could make different UIs for per device family, that take into account the different scale factors, but that is not ideal.
I posted it here, rather than stackoverflow, as I would expect this is an issue people have encountered before? Any help would be greatly appreciated!
Optionsjames_ashley ✭✭✭✭
Hi @Mag,
I'm sure you've read through this, but MS uses "effective pixels" on purpose because it provides the best reading experience. They're basically making the call for you, so that reading text on a 2D window inside HoloLens about 6 ft away is similar to reading a monitor about a foot and a half away from your face or reading from your TV on an XBox app across the room. If you really need it, creating a special View just for HoloLens would be the only way to achieve your goal. Sorry. https://developer.microsoft.com/en-us/windows/mixed-reality/updating_your_existing_universal_app_for_hololens
www.imaginativeuniversal.com5
Hi @Mag,
Yeah this is what I expected, I posted a similar question to StackOverflow: https://stackoverflow.com/q/47452892/3209889
I have also raised an issue with Microsoft to support disabling Layout Scaling on Hololens: https://wpdev.uservoice.com/forums/110705-universal-windows-platform/suggestions/32441581-disable-layout-scaling-for-hololens-trysetdisabl
