Using UI components in HUD D3D c++/cx app
Hello all, I am finding it very difficult to Create ui component in Holographic DX3d app. I need to use C++/cx since am using Opencv, and I need to build a Hud app (i have already build some functionalities , I have successfully rendered some text on the Hud view ). My problem is How can i create UI components (buttons, sliders etc) in D3D holographic app.
I need my app to behave exactly like the Hololense start menu, but i cant find any pointers on that. I do know that this is possible by using Unity, but i cant use unity since i need opencv.
to sumrize it I need to create a D3D app that behaves exactly like the Hololense start menu, renders text, images and have some UI functionalities (buttons, sliders, text boxes and events ) I think publishing the sample code of the Start menu will give GREAT benefits to all of the developers. Thanks for any help
cheers !
Unfortunately, this has to be done by the developer. If you find a UI library, that will save you time, otherwise you will have to implement a UI system yourself (rendering textures on quads for "2D" UI elements, or 3D objects as UI elements).
@Adam Do you know any UI library to be used ?
