HP Windows MR Headset Sleep Function
Hello,
Does anyone know if there is a sleep function or button to stop the MR Headset going to sleep? it seems to go to sleep after 30 minutes on inactivity. I'm developing a display for the public and need the sleep function turned off.
Thank you.
I shall suggest you to go through the following thread:
https://forums.hololens.com/discussion/6624/prevent-hololens-from-going-to-sleep5
I did go through this thread, and it doesn't help much.
It suggests solution for the hololens, while I am having this issue with the HP mixed reality headset. Mixed reality doesn't have this setting.
