Samsung Headset display is going blank while the tracked environment is visible in MR portal
So I got the Samsung odyssey today. I went through the setup and everything went well. However, when I try to use the headset, the display on the headset goes blank after like a min or so, while everything still shows on my desktop screen. I still here sound from the headsets. I have gone through the troubleshooting page and did everything it told me to do (restart the app and what now), but nothing helps. I'm currently running i5 gtx970. I've made sure everything is up to date and all. Is anyone having a similar problem or knows how to resolve this? Thank you.
Edit: i've also made sure my HDMI is properly connected and usb is connected to a 3.0 and have even changed slots
There is a more efficient way for you to solve this problem is submitting your question in Feedback Hub.
Mixed Reality Team can fetch application logs directly by Feedback hub. It is quite helpful for solving your problem. It also lets you provide screenshots. The more info you can give, the better.
I really don't want to exchange it because it has been on backorder at Best buy for weeks so I am hoping you found a solution.
I have also experienced similar issues using an Acer headset but I am running a Icore7 Surface Pro 4... Microsoft does not recommend this for MR, however it runs all the software. I have used the Portal regularly and it performs quite well but get an occasional black screen. It appears to be a Graphics Driver / Hand Controller conflict issue since the unit performs well for quite some time before screen going black.. screen tends to brighten, maybe a possible resolution change before going black usually when pointing the controller at the ground while selecting. Programs continue to run, audio and desktop remains active. Usually can re-engage the screen by disconnecting & reconnecting the my CLUB-3D CAC-1170 mini display to HDMI cable.
Former Microsoft Certified Trainer (MCT), Authorized UNIX & LINUX Trainer, Accountant.
