Samsung Odyssey HMD not working correctly with 980ti
Georg
Hi there,
I'm finally out of ideas trying to get the new Odyssey headset to work. I get 360 audio but no visual. The Mixed Reality Portal is showing the correct mirroring and tracking. I'm running it on a 980ti, running the latest NVIDIA driver (tried a bunch of different ones too and used DDU to clean up). I have stuck an ancient 660 into my rig and the HMD worked right of the bat. So I know it has something to do with the GPU. I have upgraded the BIOS to the latest Beta, to no avail.
Does anyone have experienced similar behavior or has any troubleshooting ideas?
Windows 10 Pro
Z77X-UD5h
i7 3770k
NVIDIA 980ti
Georg
I just got this headset and have the same issue. Did you get any resolutions?
Windows 10 pro
i7 4790K
NVidia GeForce GTX 980 ti
Same problem here, but with a 1060 and the Lenovo Explorer. have tried out many things, and I am curious: is your device in the device manager under monitors shown as "pnp monitor", "mixed reality device" or "[HMD Name]"? Mine was a "pnp monitor", after a manual driver update a "mixed reality device", but it did not seem like it has changed anything...
Same issue on my side as well. Have a machine set up with the following configuration:
Motherboard: ASUS ROG STRIX X99
Processor: i7-5820k
GPU: EVGA GTX 980 Ti
OS: Windows 10 Pro Version 1709
Interestingly enough, seems to work just fine on a Dell XPS I have with a GTX 960m. I'll be grabbing a powered USB hub and displayport 1.2 to HDMI 2.0 adapter to see if there is any difference and will post back.
Ended up figuring it out, an active displayport to hdmi 2.0 adapter did the trick in my case.
