Samsung Odyssey HMD not working correctly with 980ti
Hi there,
I'm finally out of ideas trying to get the new Odyssey headset to work. I get 360 audio but no visual. The Mixed Reality Portal is showing the correct mirroring and tracking. I'm running it on a 980ti, running the latest NVIDIA driver (tried a bunch of different ones too and used DDU to clean up). I have stuck an ancient 660 into my rig and the HMD worked right of the bat. So I know it has something to do with the GPU. I have upgraded the BIOS to the latest Beta, to no avail.
Does anyone have experienced similar behavior or has any troubleshooting ideas?
Windows 10 Pro
Z77X-UD5h
i7 3770k
NVIDIA 980ti
Georg
    I just got this headset and have the same issue. Did you get any resolutions?
    Windows 10 pro
    i7 4790K
    NVidia GeForce GTX 980 ti
    Hey guys. I had a similar issue where I was getting a black screen in the HMD. I reduced the resolution of my external monitor and the hmd sprung to life. I think I was due to the gpu struggling to deliver such hi res to all three screens (one external and two in the hmd)? Worth a try. Let me know. Thanks
    And just FYI. I was running a gtx 1050ti gpu. Even when I got it working it was struggling to run intensive games like space pirate trainer without glitching. I upgraded to the gtx 1080ti and it’s now all running really well without any slow downs. Appreciate the 1080ti is a bit pricey though.
    Same problem here, but with a 1060 and the Lenovo Explorer. have tried out many things, and I am curious: is your device in the device manager under monitors shown as "pnp monitor", "mixed reality device" or "[HMD Name]"? Mine was a "pnp monitor", after a manual driver update a "mixed reality device", but it did not seem like it has changed anything...
    Same issue on my side as well. Have a machine set up with the following configuration:
    Motherboard: ASUS ROG STRIX X99
    Processor: i7-5820k
    GPU: EVGA GTX 980 Ti
    OS: Windows 10 Pro Version 1709
    Interestingly enough, seems to work just fine on a Dell XPS I have with a GTX 960m. I'll be grabbing a powered USB hub and displayport 1.2 to HDMI 2.0 adapter to see if there is any difference and will post back.
    Processor: i7-5820k
    Ended up figuring it out, an active displayport to hdmi 2.0 adapter did the trick in my case.
