Experience with MeshExpert-Live ?
Hey Devs, i'm trying to build a spectator view experience for a HoloLens project.
After doing some research i found about DataMesh with their spectator view solution they call MeshExpert-Live. https://www.datamesh.com/solution/meshexpert-live
Does anyone has experience using the MeshExpert-Live product?
Or is there a stable way to use specator view from the MRTK? I know from the past that it made some big problems to integrate the spectatorview to an existing HoloLens project. However this was 6 months ago, so maybe today there is a working solution.
Any ideas?
Thank's in advance
CEO UniVRsitas
1
MeshExpert Live is a stable product now with many usage cases. You can follow this tutorial to set up your own Spectator View with MeshExpert Live!:
https://github.com/DataMesh-OpenSource/SolarSystemExplorer
Setting up a Spectator view is not easy though, you could follow this tutorial.
If you have any question, you can always email to service@datamesh.com for help and support.
About integration, this tutorial also gives concrete examples. The procedure is easy:
