Hologram stabilization
We're developing a Hololens application, but our object shows a large amount of jitter when moving closer to/further from the object.
I know the stabilization plane has to be set for that, but I don't know the ideal setup for the stabilization plane.
What would be the ideal solution for stabilizing the holograms, given that it has to work with both a big hologram (about 10x4x4m) and a small hologram?
Thanks in advance.
Which version of Unity are you using? I am running into tracking issues on 2017.3 and 2017.2.1f1. No issue on 2017.1.2.
I think this might have to do with the hologram complexity - if your holograms have a high polygon count they'll exhibit jitter.
Unfortunately I can't help you there. We're using Unity 5.6.3f1.
High poly count meshes do have a framerate impact, but we've already done a pass to reduce the poly count and get an acceptable framerate. Additionally, the jitter I'm experiencing is when I move towards/away from the object in question. The earlier version just used a fixed distance stabilization plane, and there the effect was a bit noticeable. If I set it to the object's position, it's perfectly stable when looking at it from a distance, but standing inside the object causes it to massively when looking in the wrong angle.
Oh, standing 'inside' the object can be an issue. I think at that point you are standing on top of the stablization plane. This article states 'Don't let the stabilization plane cut through the user' which may be the case. Try setting the plane to something further away.
https://developer.microsoft.com/en-us/windows/mixed-reality/hologram_stability
