HoloToolkit -- this is great stuff!
DeckTwelve
in Discussion
Reading thru the code from the posted Academy articles and am really excited to see amazing stuff in the HoloToolkit!
One of the things I was not looking forward to doing myself, transforming spatial mapping meshes into planes, is in there ready to use (check out HoloToolkit\SpatialMapping\PlaneFinding.cs). Here's a link to the Academy article with the download.
Has anyone else read thru the code in the HoloToolkit? What are you most surprised to see or excited to use?
1
Is it just me, or is the toolkit/emulator download link not going to be posted until March 30?
That's correct, but some of the sample projects appear to be up on GitHub if you want to start looking at how code works.
https://github.com/Microsoft/HolographicAcademy/branches
Thanks DeckTwelve! We look forward to seeing how the developer community will use and expand the toolkit. PlaneFinding and RemoveSurfaceVertices (which can help you blow a hole in the spatial mapping mesh), are two of my favorites
I have installed Unity (5.3.3f1) and Visual Studio 15 (update 2). At the moment I am getting build errors but I understand this is due to not having the emulator yet. Will this be a separate install or will I need to reinstall Visual Studio?
You'll be able to install the emulator separately once available.
@CoreyGoff Great - thanks
After playing with the HoloTookKit i can see how easy this will be to start creating basic viewers with minimal data. I attached the Hololens Cursor (included in kit), currently trying to get this thing running without the emulator.
