Mixed Reality 250 has one big Error after trying to deploy
Hello,
I was trying to do the Mixed Reality 250 Academy from Microsoft and in Chapter one I already get stuck because of one big Error Message.
Is anybody else experiencing this Error after deploying with Visual Studio ? There are annother 19 Warning Messages but I think the one Errormessage is enough to begin with
The Message ist attached as an extra File because it's too big.
Hope somebody can help me.
Regards
OptiLenso
OptionsJayZuo mod
I'm using Unity 2017.3.0p1 with Visual Studio 15.5.4. I can build and deploy the project to Hololens with no error. You may update your Unity and Visual Studio both and try Mixed Reality 250 again from scratch.
According to your error, it seems you are facing the same issue here: .NET scripting backend and Visual Studio 2017.3 incompatibility.
Upgrade your Unity should be able to fix this issue. Currently, the Mixed Reality 250 project used Unity 2017.2.0f2-MRTP. You can use a version later than this from 2017.2 Mixed Reality Technical Preview builds. Also, you can use Unity 2017.3 which is Microsoft recommends against for now.
Thank you @JayZuo for the answer.
The problem is, I am already using Unity 2017.3 (0f3).
I updated my Unity anyway. But as expected the Error is still there.
Any other suggestions?
Thanks @JayZuo
After Testing a while I got the same problem on my other projects. So I updated Unity to 2017.3.0p1 and after that it worked again.
I also tested the Mixed Reality 250 again, but still the same big Error message.
