Mixed reality portal setup
At the end of the setup process:
"Before we finish setting up Windows Mixed Reality, you'll need to restart your computer. Then go to Start > Mixed Reality Portal and we'll get you going."
This is a 100% fresh Windows 10 install. The operating system is updated. After that I have installed Chrome, Graphics drivers and then plugged in the Samsung Odyssey HMD.
I have no idea of how to resolve this. The only odd thing I can possible find with this system is that update KB4054517 refuses to install.
There is a more efficient way for you to solve this problem is submitting your question in Feedback Hub.
Mixed Reality Team can fetch application logs directly by Feedback hub. It is quite helpful for solving your problem. It also lets you provide screenshots. The more info you can give, the better.
I'm having this same issue. Did you find a solution??
