Disable 30 min time-out before going to sleep
I want to attach the HoloLens to a rig and want it run for ~8h unattended, powered from the USB power supply. (No human interaction for more than 30 min)
However, there is time-out in the device portal, under Sleep-Settings, that only offers the values for "When plugged in, turn off after" from 3 min to 30 min.
I need to set the sleep time on the order of 8 hours or infinite. There seems to be no difference for Developer Edition and Commercial Edition.
Microsoft, can you please change this? Or is there a workaround?
Optionspstueven ✭✭
Have you tried editing the option of the select in the DOM? Just an idea, maybe they do not check it before setting.
Edit: Well, it worked for me. Let me know if you need any assistance how to do it.
Interesting: there are even more options in the /api/power/cfg/SCHEME_CURRENT? response available than are shown on the webpage.
Someone should try to find out how to use them...
I found an earlier duplicate of my question, with the same method. If you set timeout to 0 it will never go to sleep:
https://forums.hololens.com/discussion/6624/prevent-hololens-from-going-to-sleep
In the official documentation, there is no information:
https://developer.microsoft.com/en-us/windows/mixed-reality/device_portal_api_reference
However, here is a Unity-script that can set the sleep timers from the HoloLens. Great!
http://www.tattichan.work/entry/2017/07/17/
