MRC portal or Hololens Companion. authentication is bad design for streaming.
Authentication requirement to stream live video via laptop is a bad design.
Why even need authentication to access the HoloLens if it is wired with USB?
Isolate them from authentication.
I'd say the authentication is probably needed so that someone just can't hack into your video feed by figuring out your IP address. It is kind of a security issue to have an open IP address. The Device portal also contains a lot more information than just a live stream. It also contains all of your app files on it. As well as the power to install, uninstall, start, and end apps just with a few clicks. Not to mention all of your photo and video files.
As far as why you need it for a wired USB that's as simple as someone stealing your device and plugging it into their computer and doing the same thing.
AR Developer
