repetitive kernel debugger error when using WMR
Hello I have an app that keeps crashing on WMR but works fine using hololens the error is the below :
CallContext:[\PublicAPIActivity]
onecoreuap\windows\analog\input\mirage\stubdll\holographicspace.cpp(390)\Windows.Perception.Stub.dll!0F551A21: (caller: 0F898204) ReturnHr(17988) tid(3260) 80070057 The parameter is incorrect.
Exception thrown at 0x772D08B2 (KernelBase.dll) in MSIApp.exe: 0x40080201: WinRT originate error (parameters: 0x80070057, 0x00000057, 0x054FE25C).
analog\input\mirage\publicapi\holographicspace.cpp(340)\Windows.Mirage.dll!0F29A971: (caller: 0F551A04) ReturnHr(17994) tid(3260) 80070057 The parameter is incorrect.
onecoreuap\windows\analog\input\mirage\stubdll\holographicspace.cpp(390)\Windows.Perception.Stub.dll!0F551A21: (caller: 0F898204) ReturnHr(17989) tid(3260) 80070057 The parameter is incorrect.
analog\input\mirage\publicapi\holographicspace.cpp(340)\Windows.Mirage.dll!0F29A971: (caller: 0F551A04) ReturnHr(17995) tid(3260) 80070057 The parameter is incorrect.
onecoreuap\windows\analog\input\mirage\stubdll\holographicspace.cpp(390)\Windows.Perception.Stub.dll!0F551A21: (caller: 0F898204) ReturnHr(17990) tid(3260) 80070057 The parameter is incorrect.
analog\input\mirage\publicapi\holographicspace.cpp(340)\Windows.Mirage.dll!0F29A971: (caller: 0F551A04) ReturnHr(17996) tid(3260) 80070057 The parameter is incorrect.
My laptop specs are :
Model : Lenovo Legion y720
VGA : Geforce GTX 1060
Visual Studio : vs 2017 community latest version
Thank you
With current error message, it's hard to say where the problem is. However, please note HoloLens and Immersive headsets are two different platforms. Not all functions working in HoloLens can be used in Immersive headsets. You may first check if you are using some functions or APIs that not supported in Immersive headsets.
Actually the same code is working on another pc with same specs
